Personalize User Queries
About Personalized Queries
Personalized queries are used to filter and boost search results.
This can be done one of the two ways:
- Use the SmartHub user interface to set your options.
- Use the Tuning stage method below, which offers you an easy-to-use GUI in a SmartHub tuning stage.
Be aware that the order of relevancy stages order can impact the way documents are boosted.
The default priority order is:
- User Relevancy
- Personalization
- Admin Relevancy
Limitations
Some SmartHub Features are unsupported by some search engines.
For information about limitations to your search engine, see the "Limitations" topic for your search engine.
Personalized Query Tuning Stage
- The Personalized Query tuning stage enables you to append information to an actively running user query.
- This stage requires you to set the User Profile settings.
- The appended information is generated based on the users’ User Profile properties such as Department or JobName.
- Use the steps in Add a scripting stage to add the Personalized Query stage.
Available Personalized Query Tuning Stage Settings
| UI Elements | Description |
| First match | Enables the query processing stops at the first match per keyword |
Keyword |
| Included Result Sources |
| Excluded Result Sources |
| Type | Enables the user to select the keyword type. |
| New Keyword (button) | Creates a new keyword with all the properties associated to a keyword. |
| Delete Keyword (button) | Deletes the selected keyword. |
| Partial Match | A toggle that enables partial matching. |
| Addition |
The user can specify a property that is used in the condition check for the addition. |
Generate property format value button Shown in the example graphic below.
Enables the user to specify the value for the property used in the property format text box. |
Enables the user to specify a default value that is used in case that the dynamic property value entered does not exist. |
Deletes the selected addition. |
Enables the user to reorder the additions. |
Personalize Query Tuning Keyword Example
See the following graphic (appearance of window varies, but fields remain the same) for examples of various Personalized Query tuning stage parameter values.
